TwinTurbo.NET: Nissan 300ZX forum - With an upgraded clutch it helps to do a couple things.
Subject With an upgraded clutch it helps to do a couple things.
Posted by Audioquest on April 11, 2008 at 10:06 AM
  This message has been viewed 137 times.
In Reply To Re: Did you b;eed the point on the pass fender well posted by frank1991(running again) on April 11, 2008 at 10:02 AM
Message First, under the dash at where the pedal rests at the top, there are 2 switches. Back them out evenly until there are only a couple threads showing past the lock nut.
Now adjust the rod so the pedal raises just until it activates the switches, not until it bottoms out.
If you do this and all the air is out of the system, you will have about 1/2" of play at the top and your clutch will fully disengage a couple inches off the floor.
